I just pulled of a shitload of piping looking for the thermostat, I should've checked here first cause it is not located where every other cars is. dammit! anyone care to enlighten me with the secret location of the thermostat?
so does that mean its at the end of the bottom coolant hose? as opposed to at the end of the top coolant hose where I just took off A SHITLOAD OF FUCKING PIPING:cry:?honestabe said:It's underneath, tucked up high near the front of the motor. It's in a bitch of a location. Good luck replacing it, it'll piss you off.
Adam
I can't believe I took almost all of the piping for the twins trying to get to the end of the top coolant hose:3d_frown: when I got there I was like...what the hell? where did it go? than I read some stuff about some people not finding a tstat when they opened up their shit so I thought maybe it didn't have one... but then I followed the bottom coolant hose and it took 3min with the right tools. it sucked.AF1JZ said:Follow the lower radiator hose to the block and you'll find the thermostat housing. Take off the hose and then it is 2 12mm bolts holding it on there. You can get to it from the bottom. It isn't hard at all the change out.
87Superdupra said:I can't believe I took almost all of the piping for the twins trying to get to the end of the top coolant hose:3d_frown: when I got there I was like...what the hell? where did it go? than I read some stuff about some people not finding a tstat when they opened up their shit so I thought maybe it didn't have one... but then I followed the bottom coolant hose and it took 3min with the right tools. it sucked.
OneJoeZee said:If doing your thermostat was hard, pray to good your turbos never start smoking.![]()
Sweet... so I guess I should do my thermostat, again:3d_frown:Ric said:Get toyota OEM stat only.. those stant ones suck
87Superdupra said:Sweet... so I guess I should do my thermostat, again:3d_frown:
