Where does this wire go? With pictures
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I found this wire unattached in the bay just above the battery area. It is a single small wire, looks like a ground. If anyone knows for sure, or can go outside and look and find out where it attaches to that would be greatly appreciated :icon_bigg It is the brown wire with blue end piece. It is screwed in a bolt, and another set of wires are around the same bolt under this wire, but not of the same set.
eric
shaeff
Kurt is FTMFW x2!!!!
11
Around
Looks like a simple aftermarket crimp connector to me. Someone probably used it as a ground for something. It looks like it has blue insulation on the actual connector. I think all of the OEM grounds are bare connectors.
fool'ssupra
Building It
Sep 14, 2008
75
Maryland
Most automotive manufacturers don't insulate the barrels on ground wires. Probably keeps the cost per vehicle down by some small fraction.
