where did you relocate your charcoal cannister to?
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
Oh okay I'll probably just find some metal brackets and bolt it down from osh or home depot.
Why use a jz canister? I've never seen one. The tercel one I have is probably 1/4th smaller than stock.
the jz is a lot smaller also. That's what I use, but I have it hid in my passenger side fender well.................don't none of you try to steal it either since I told you of it's secret location.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
Just grab yourself a tiny one off a Kia Spectra and take the 2 bolt bracket off the firewall while your at it. You could fit that thing anywhere and run the line out through the fender. Just make sure you source a check valve with the correct crack pressure as Kia's don't run one.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
There's a few people on here that are running a JZ CC because of it's small size. I also hear that some of our North American models of Lexus' use the same CC.
Here's a pic for reference.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
err.. Vacuum pump?
First time I've seen the JZ Canister.... this is an automatic win for anyone looking for a better solution. Don't even know why there are these type of threads when this option is there!
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
That is a pretty cute charcoal canister! However, if we use that on a US spec car, it creates room on the hot side. I believe it would be a nice cosmetic enhancement, even if you aren't adding a catch can.
dmiller
suspension>power
Jun 30, 2009
210
Vancouver, Washington
supra90turbo;1438831 said:
err.. Vacuum pump?
Yeah i looked in my tsrm and the part in the way of where i would mount my catch can is called the vacuum pump according to the book
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
err.. Vacuum pump?
Yep, that's a vacuum pump. How else are you going to keep vacuum to the cruise control actuator when the vacuum system comes under boost while driving? (Like going up a hill).
dmiller
suspension>power
Jun 30, 2009
210
i removed the cruise control actuator and plugged the line for it
Hmong_1G
Name the Place and time.
Dec 31, 2008
280
California
I have my original Charcoal canister, but tossed my heater control valve. My greddy Catch can sit nice in tight without heat soaking. Only true heat I have notice is from my feed line from the valve covers.
