Satan said:Help me out... post pics of your wheels, their fitment, offsets and size/width. I can't believe there not 1 single thread that shows 'em all.
What would be most beneficial would be measurements to the suspension and fender rubbing. That way you could plug in the measurement/offset for any wheel and width/sidewall of any tire and find out if it would rub somewhere.
You'd need different measurements based on stock height and average lowered height.
Could also do a flash animation thing so that you could see how far out the rims/tires would stick at different offsets.
That would eliminate the need for pictures of a Supra at different heights with an infinite # of rim/tire combination.
Actually - I'm sure someone could make a flash animation where you could select what suspension is on the car - taking into account only the rated drop (no spring sag for tired setups could be included). Then you choose what rim size/offset and tire size. You could even go crazy enough to throw in an option to roll the fenders.
Be warned however that there are an infinite # of combinations here. This would still take care of the majority.
