Wheel questions
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Id see if you can get them in a different offset mainly in the front. A 20mm offset in the front is going to cause tire to fender lip clearance issues. The other thing is find out how heavy they are. They look nice (for a knock off), but I'll bet that they are heavy as sin and not worth it when you can get light weight wheels for about the same price.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
I have 19x8 +20mm offset for the front. It fits perfect, right out to the fender. You shouldn't have any problems with the 18x8.5 +20. But you won't be able to fit anything wider then 235. Mine goes right up to the fender, a few millimeters gap, anything wider and it rubs. I haven't rolled the fenders, but if you do, you might be able to fit 245s on it.
p5150
ASE and FAA A&P Certified
Central Idaho
Im looking at some similar wheels 18x8.5 245/40/18 +20 in front and 18x9.5 275/40/18 +40 rear
Im not sure if these will fit though. Still looking at other setups.....
