How would 17x8.5 +58/18x9.5 +65 look or fit. And what tires would you guys recommend?
Sent from my Nexus 6 using Tapatalk
Not sure what you need adjusted, that's pretty decent fitment. Usually people go a bit too wide with XXR's and they don't have the offset right. Yours seem to tuck in quite well.PeterSupra51984;2090840 said:I know I need some adjustment but really satisfied with the result... I have some xxr 531 hyper silver with 18x8.5 (+35) on front and 18x9.5 (+35) on the rear with 225-40-18 on front and 255-40-18 on the rear
Supra0089;2091264 said:Can you guys help me size wheels for my supra? I don't want to roll fenders if possible and I think I want to stick with 18's all around (unless you can convince me to go 17's). I'm looking to get Cosmis Racing XT 206-Rs.
https://www.cosmisusa.com/product/xt-206r-2/
Sizes available:
17×8 +30mm 5×100 & 5×114.3 CB: 73.1
17×9 +5mm 5×114.3 CB: 73.1
18×9 +33mm 5×100 CB: 73.1
18×9 +33mm 5×114.3 CB: 73.1
18X9.5 +10MM 5X114.3 CB: 73.1
Thanks for the sizing help in advance.
gsxr141;2091289 said:18x9 +33 is your best option you listed. 235-40 fronys and 255-40 rears
Grandavi;2091290 said:Agreed, the 18x9 +33 with a 255/35R18 tire will put you even with the outer quarter panel. (maybe just slightly past, but not visually). You will probably only rub on really big bumps. My old Work wheels were a +42 offset with 255's and the quarter panel lip would just touch the sidewall top portion if I hit a big dip at about 140 kph. Other than that, they never touched. (mind you... my suspension is a bit stiff)
Tires have different "shoulders" so on a rounded shoulder, you probably would never have an issue. My tires were sharp shouldered. Don't forget the hub centric rings though.
gsxr141;2092010 said:of those sizes, 18x9.5+27 is your best bet. that wheel also comes in a 18x10.5+30 size, but you'll have to roll the fenders for that one.
