supradragontoy;1356642 said:Isn't there an idle adjust screw on the throttle body? I know some things are different from ge to gte, so I dunno. If there is, try backing it off 1/4 turn or 1/2, but keep track so you can put it back just in case. Last time I had idle issues after warming up it was the TPS and a bad brake booster grommet and check valve. Just a thought
No there isn't a idle screw on the TB. At least one that you're suppost to screw with
