gdc5ind;1360229 said:Look at the crank and the cam gears....
gdc5ind;1360396 said:I thought the car sounded weird, and i noticed the timing was of so I did a compression test and leakage test. It passed the compression test 152 all the way down, the leakdown test was a different story. It failed on two cylinders, the exhaust valves were leaking.
gdc5ind;1360401 said:Its off by one tooth on each cam gear. In this position the cam gear should be straight down and its not. The car sounded like shit, and that what mad me check the timing. Do you think ths valves DONE?
