Supracentral said:Ideal, that is one of the coolest damned little fittings I've ever seen.
That would have saved me a world of hurt a couple of months ago...
haha its amazing what a little simple google search can do
IJ. said:A Lathe a CNC Mill and a full set of taps and dies helps here![]()
theKnifeArtist said:hey so i took the stock one off. how does this thing actually work if there arent any wires going to it?
theKnifeArtist said:does it? man i don't remember taking that off, guess my friend got that one. thanks! i should put teflon tape on the threads right?
Idealsupra said:i personally wouldnt if you have the proper threads....however it wouldnt hurt anything if you did so.
3p141592654 said:BY the way, the stock pressure sender is not your typical variable resistance sender, it actually outputs a digital pulse train whose period is proportional to the pressure. Also, it is an input to the TCCS for idle stabilization.... strange but true!
3p141592654 said:I am not sure how it will behave without it, but pin S-7 on the TCCS is connected to the oil pressure sender.
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?Section=Main&Page=48
Idealsupra said:heres what you need:
http://www.egauges.com/vdo_acce.asp?Subgroup=BSP_Adapter_Bushings&Manf=All
this one that has extra ports for other sensors if you wanted:
http://www.egauges.com/vdo_acce.asp?Subgroup=BSP_OTOD
