Whats the highest boost on Lexus/550 set up?
Koenigturbo
1,337
Oxnard CA
Searched,Where's the link;
I have the Lexus A.F.M., 550 injector, 3" exhaust, stock inner cooler and upgrade 57 trim on a ct/26. Whats the highest boost you can run on this set up with out hitting fuel cut?
Supracentral
10
You're probably going to be well out of the efficiency range of that turbo at 20 psi. With the right tuning you can get 20 psi out of one of those, but it's not efficient and the turbo likely won't last very long.
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
I have a similar setup, but with a stock CT26... I run it at 13psi, as anything above that is worthless due to inefficiency (as already mentioned).
mdr40z
arkansas
without fuel management you are lucky to get much past 12, with an afm 18 or so and yes even 20ish
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
yes i done it i ran 22 with sfac intercooler lex 560 blaa blaa blaa after 20 you really stop feeling any gains and it shows on the dyno
NashMan
Aug 5, 2005
4,940
17
Victoria BC
57 trim
and i never got my car on the dyno at that level of boost ebc broke
i did 347 and 398 truq at 11 psi
then 3 dasy laetr snaped the shaft on my ct cause of over boost/ bov did not go off
my buddy wiht about the same setup got 457 at 21 psi with a 57
then cuople of mouth later bumped his base timing to 13 and blew his rings out shows yae what 3 dagress of timing can do eh
LilMissMkIII;1230590 said:
Stock CT26, or 57 trim? And how much power did you make on the dyno?
Koenigturbo
1,337
Oxnard CA
MK3Brent;1230955 said:
Scale back the Hz correction with a piggy back, up the FP, and you'll never see FCO. :)
probaly the best answer I've read so far, one problem: "scale back"??? I guess that's a qeustion for a later thread. or ask tech support (Greddy) up the f.p.?? to what p.s.i.?
Thanks!
