To control/lower EGT with higher compression engines?Poodles;1839198 said:Hint: EGR wasn't originally designed for emissions![]()
suprageezer;1839081 said:I'm thinking two off the top of my head, one is a company thing the other and entire government mandated design.
First the deadliest car ever made the 65,66, 67, 68 mustangs, the gas tank is in the trunk, the only thing seperating you and a fireball in the rear end collision is the back seat which instanly incenerates. Google it, it's always been a huge Ford/Gov lets keep this quiet. The fact is over a million were produced, so many have lost their lives and continue being killed today due to it's poularity.
http://www.youtube.com/watch?v=3FioZOhoXCw&feature=results_video&playnext=1&list=PL0EB1C8FB2CA795B2
Second the EGR valve, the good ole Exhaust Gas Recirculation Valve. Now who ever thought of taking hot exhaust gas right out of your exhaust manifold then introducing it directly into your intake manifold after the point where the air was FILTERED has got to be the King of American Built In Obsolecense. Along with these gases comes a certain amount of diamond hard carbon particles, one can only imgaine what wonders they do in your combustion chamber, especially between your pistons and cylinder walls.
bioskyline;1835832 said:the clock in the supra is wired to the taillights to http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=128
You had time to watch the oil pressure gauge? I was always too busy trying to manage 3 pedals, 4 tires, and 5 gears, and 7000 rpms to pay much attention to much else.Poodles;1840263 said:Ohhhh, I got a good one. How about the "idiot light" gauge on the Miata? Early miatas had a real, working oil pressure gauge. later ones, it's still a "gauge" but it's not triggered by an oil pressre switch on the block. If you have any oil pressure, the gauge goes to a bit over half and just stays there. Not very helpful at all :rofl:
suprageezer;1842123 said:Then there was the ole Ford sending 15 amps through a Texas Instruments Switch rated for 1-2 Amps that pluged into the brake master cylinder. It had power all the time if I remember right, so when your truck or car was just sitting at home in the garage and the switch sprung a leak, your brake fluid would catch fire, your vehicle would burn, then burn your house down. I wonder how many are still out there like that on the road.
http://deliciadawn.files.wordpress.com/2011/04/iaai_article.pdf
What's quicker, hydraulic pressure or an electric signal? I'll stick with the good old fashioned electrical based lights. Don't want any delay in my brake lights illuminating...IBoughtASupra;1847542 said:VW use of a pressure activated brake switch in the brake lines that control the brake lights. Why is it dumb? When it blows, it doesn't just go bad, the spring breaks out, causing a hole in the switch and fluid rushes out with every press of the pedal.
