88 7mgte, stock ct26 on 8lbs, 80k miles
when i go over 3500-4000 rpms my coolant temp gauge drops to 0 and it runs poorly when in boost (over 4000rpms). my most likely suspect is the coolant temperature sensor. On the thermostat housing, I see there are two different (what appear to be) temperature sensors.
www.oreillyauto.com/site/c/search.o...3&keyword=coolant+temperature+sensor!s!sender
I tried alldata, but it wasn't really any help. What is the difference between those two sensors?
