Whats the biggest Hot side A 7m can run
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
Well, if you can get your 7m to spin to 10000rpm, you can run a 1.15 and make boost at 8000rpm........ :bigthumb:
I would guess .83 for stock redline.
Tubbie: Depends on the Wheel size.
A little wheel at 1.15 ar would spool fine and large one wouldn't.
All comes down to volume of gas flow ie: either bigger motor or more RPM will spool a larger turbo.
Clueless
980
Columbus, Indiana
I have a t04b with a 1.32 a/r turbine housing with a P trim wheel...
my old 14b turbo compared to my t04b...
spoolint78
Representing T.O
T.O
my buddy runs over a 1.00 a/r on his 7m
i always telll him to make it a .81 at least.
no wonder the fucker runs 13.2 or whatever @120+ mph
He just built a 10,000cdn head.
Billet cams, 2mm oversize valves and everything.
Doesn't post much, but he does run a huge a/r
boost PSSH boost
SM's Welding Guru
Apr 4, 2005
465
Marshall, WI
I ran a 1.00 a while back...not by choice, I couldn't find a smaller one at the time and just ran with it. veeeery laggy.
1.21? sheesh....look on ebay for a smaller housing.
Adjuster
From what I'm finding, the BB GT turbo's can run slightly larger hotside AR's and still spool fine on the street, yet flow more on top as a result. (But they spool up even faster with smaller AR's, but you lose some flow as a result.)
Classic trade off here. High power, or driveablility.
I choose driveablility personally. (But the larger housing might be fun on a dyno or the drag strip if you have some way of building boost off the line, N20 or an automatic trans for example.)
