Whats the best BOV i can run?
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
I did some research and i was sold on the synapse syncronic blowoff valve. It is a pull type bov which doesnt use a diaphram and is said to completely eliminate compressor surge. It is said to outperform HKS and was the sema 2007 product of the year, but fore some reason it hasnt really caught on yet. I've yet to install mine so i cant tell you first hand. check it out for yourself. www.synapseengineering.com they also have videos of their products on youtube.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
honestly the stock bypass valve works great.
i used the synapse on my single 2jz when my hks surged. worked pretty good
Turbo Habanero
4,229
Tucson,AZ
I seen a couple different comments on how people thought the stock valve was crap. But thats why i thought i should ask.
My motor was just rebuilt everything was done from Radiator to cam and pistons.(only about 200miles so far). Running Metal HG and ARP studs. i was told that i need to re-tighten the Head down after 200miles because it tends to Float. Have you ever heard anything about this?
I was also thinking about going with the HKS Ssqv specific Kit for the 7m-gte
http://www.jscspeed.com/mk3/bov/hks_bov.htm (would you think this was a safe bet to throw on)
I am running close to stock specs (Stock Boost)
tlo86
Jul 24, 2005
3,914
Colorado
i like the synapse because its essentially very adjustable for how much air you would like to go out heh, and can replace 2 bov's if you want 0 surge and still get it
but really get one if you need it otherwise leave it heh
Mk3runner
2,033
Nor Cal
I'd run stock bpv until your ready to step up your setup. Head studs and 200 miles. Been though a few heat cycles eh? Almost time to retorque maybe, got tq wrench?
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
Turbo Habanero;1397924 said:
Another question? I only get partial boost in 1st and 2nd And full 3rd-5th.
Heard it was made to do this?
It takes a load on the motor for the turbo to spool, and in 1st and 2nd there is not much of a load to overcome so it boost a small amout then go back to 0 psi. For instense going 30 in second there is no boost but you are revvving somewhere between 3-4k, put it in fifth and floor it there will be almost instant boost at 1500-1800 rpm and full boost around 2-3k.
Altezza576
268
New York
I have run the HKS SSQ and the Blitz DD with much sucess. I currently have the TurboXS type H? on my MK4. and I plan to reinstall the Blitz DD on the MK3
wsharp23
29
Grover Beach, CA
Has anyone heard of a hybrid BOV for the mk3? One that will let out some of the vent to the atmosphere and some back into recirculation so that the air fuel ratio wont be too messed up??
JDMMA70
2,550
Houston
you mean like running two? The aftermarket and stocker? It can be done i did until my stock one died.
