Whats included in a 5 Speed Swap?
Idealsupra
Orlando
www.tampabaysupras.com
tranny (duh ;) )
shifter
shift knob (optional)
driveshaft
tranny wings (supports on the side of the block)
inspection plates
dust cover for bottom half of tranny
slave cylinder
master cylinder
clutch lines (hard and soft)
pressure plate
flywheel
clutch disk (you should replace anyways)
clutch fork
brake pedal (5 spd version)
clutch pedal
i think that about covers it...ive sold a couple of conversions like this...they run around $500 for the whole conversion set.
ma71supraturbo
Redding, CA
www.geocities.com
one of the lower transmission supports ("wings") is the same on automatics and 5-spds. I can't recall which side it was though :(
You'll also want to make sure if you have ABS, that you get a transmission from a car with ABS. The automatic sensor will not fit in the manual transmission...
Poatree
62
Edmonton
www.shiftin.com
i think you need a driver side wing...
ma71supraturbo
Redding, CA
www.geocities.com
Poatree said:
nope, apparantly the a/t ecu works with the 5 speed.
Correct. You will just have to short two wires to make the ECU think you're in neutral (allowing you to start the car), and will need to wire reverse lights. If your car has cruise, you'll need to do some other wiring, but my car doesn't so I can't help ya there
