mazzer said:no pics but i can make it happen.
I don't think that the fitting is diffrent b/w the T04b and the T04e, or am I wrong?
It all depends on the exhaust housing as to which manifold can be used.pearlwhite turbo said:I don't think that the fitting is diffrent b/w the T04b and the T04e, or am I wrong?
aye mate said:Why? All the turbos that bolt to the stock manifold are internally gated. I think you need to research turbochargers more because not many of your questions have really made any sense. IMO.
pearlwhite turbo said:Well The turbo That I'm Using T04b garret, does not have an internal wastegate.
aye mate said:Does yours bolt to the stock manifold?
supramike7m said:yea mate, those turbonectics do bolt on the were made for our cars, they use the same type of housings, so you can bolt to your manifold, and downpipe. most to4 will not though.
pearl white, you really need to do some research on turbos man, i agree with aye mate, your questions dont make sense. if you have a to4 turbo you need a adapter or t4 manifold. unless its a bolt on deal like the jt, boss, or turbonectics bolt on. if you dont have a internal wg. its not bolt on, get an adapter or a manifold, external wg, lines, and custom Down pipe.
