I've been research'n the subjest but I'm not getting anything can anyone point me in the right direction? Whats better? If the ebay manifold has clearence problems, is it superior then the stock?
oscolivar1 said:well if u running stock ct then u have to stick with the stock mani.
the ebay Mani's are tubular so yes... they are better than stock, but if your using the Ct-26 upgraded or not the stock mani does a very good job as far as flowing.
hope that answers your Q
oscolivar1 said:u might wanna do more research b4 u wanna swap your mani or turbo.
the only turbos that can bolt on to the stock mani is SP, JT, boss, and the CT
and i think one more but i cant remember. Plenty of people on here have pulled over 450+ hp on the stocker mani.
yes its better to swtich to a tubular mani as long as the flange matches the turbo.
pearlwhite turbo said:Check this out, let me know what you think.
http://cgi.ebay.com/ebaymotors/TOYO...tegoryZ33742QQihZ006QQitemZ160072431960QQrdZ1
CryoSlash said:i dont like the ct26 at all... but that other link is a crazy deal!
themadhatter said:if you wanted to improve the flow of your stock manifold get it extrude honed that will bump up the exhaust flow a bit
no pics but i can make it happen.pearlwhite turbo said:That t04e fit right onto the stock manifold? do you have any pic's
