What type of Motor Oil do you use for your Supra Turbo?
Status
Not open for further replies.
jonahs_supra
1,015
Lancaster, Ohio, United States
Castrol gtx 10w30
Used in my 01 silverado. Change oil light came on at 4500 miles
Tried valvoline 10w30 on next change and change oil came on at 3000
Test number 2
castrol gtx 10w30 in my 09 corolla change oil light came on at 4500 miles
Tried valvoline again and Changed out at 3000 miles
So now i use castrol gtx and Toyota filter
1 qt over full
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
jonahs_supra;1831787 said:
Castrol gtx 10w30
Test number 2
1 qt over full
Crack me up.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,239
Atlanta
Ive heard them called idiot lights?
What is connected to the other end of that light circuit that knows when your oil just isnt 'cutting it' anymore?
Supracentral
10
Good name for them...
In most older systems it's based upon simple mileage. There area few newer systems (BMW's Condition Based Service System and GM's Oil Life System as examples) that factor in driving conditions. However they are all "guesses". None of these cars are running around with a hidden gas chromatograph actually testing your oil and doing a TBN analysis...
None of the systems are aware of the quality or type of oil you've installed, only factors like temperature, rpm and road speed...
Supracentral
10
In most older systems it's based upon simple mileage. There are a few newer systems (BMW's Condition Based Service System and GM's Oil Life System as examples) that factor in driving conditions. The BMW system also performs an "oil quality test" via the electrical conductivity of the oil. As the add pack wears out, and contaminants take up residence in the oil, the resistance of the fluid changes. BMW says they've found this to be more accurate. (Btw: The BMW system will always suggest a change once you hit 15.5K miles without a reset regardless of what it thinks of the oil...)
None of the systems are truly aware of the quality or type of oil you've installed or the actual useful life left in it, they are only guessing.
mecevans
1,295
M-bay, cali
jake8790;1831997 said:
The GM system takes into account the number of cold starts, number of engine revolutions, etc.
And that the customer uses dexos aproved oil. I forsee allot of them having their warranty voided. :biglaugh:
jonahs_supra
1,015
why do the oil lights come on at different mileages when using different brands of oil?
same filters used and same 80 mile trips to work 5 days a week on each vehicle?
toyotanos
What will we break today?
2,842
Coon Rapids, MN
Perhaps because they weren't reset correctly? No reason a different oil or filter brand would cause the light interval to change...
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Poodles;1832167 said:
All these people running 10w-30 or 40... Makes me sad.
No kidding. Same here.
Saying you run a base 10 oil shows you're not aware what that number means. Saying you run a 40 hot oil shows you either have a trashed engine you're trying to limp along, you have a race built engine that only sees track days (pretty sure that's less than 0.1% people on here) OR finally, and most likely, you dont understand what that number means.
Supracentral
10
xzeror
1,356
Miramar, FL
how much do you guys put it? I have a 2jzgte and i have 5 bottles (5qts) of german castrol... How many qts do you guys recommend I put in?
Supracentral
10
Run six. I always run six quarts in a 2J.
80083r
So, my engine leaks a little oil from the oil pan seal I *think*. I did an oil change this spring with 5w40... did I do wrong?
By a little, I mean that if I drive the car fairly hard and then park it overnight, there are 2 or 3 drops under the car in the morning. If I drive it easy - no drops.
Status
