I am going to be swapping in a GE in the next month or two. Once the GTE goes in I can't decide what to do with the GE. It is the original engine and has never been rebuilt. I burned a valve and had the head rebuild and resurfaced. It was put back on a torqued back down to 75 ft/lbs on stock bolts. It has a small vacuum leak in the lower to upper intake manifold. There are some random small things I need for the swap I could either buy from a partout OR take off of the GE. Should I keep the GE complete and sell it as a running motor or part it once it comes out and use the parts I need for my build? It does burn some oil since the rings are original as far as I know. Thanks guys!
