I recently installed an oil pressure gauge in my car with an aftermarket electric seding unit, as you know the port for oil pressure is right under the exhaust manifold and already the plastic on the sender is starting to melt. I was ondering what most of you guys do for this, should i wrap my stock exhaust manifold uinder the heatshields or should i wrap the sender with heat protective wrap or do you think i should just get an extension hose and mount the sender elsewhere in the engine bay via hose. Thanks.
