ok check it out, i have an 86 supra n/a 7mge a/t all stock i got about a month ago noticed i had white smoke coming out tail pipe, i bought some copper seal to temporarily fix possible head gasket problem before i put the copper seal in i decided to degrease the engine and clean it (check for leaks etc.) i started car which i didnt realize was running on empty - the engine started to rev rpm goin up n down up n down -more smoke ? i checked oil and the water from when i cleaned the engine went into the engine ?? i put copper seal in let the engine continue to run as directed then shut off for 24hrs. -next day car wouldnt start i replaced the plugs, wires, cap, and rotor then i was back running ,the smoke was gone only problem is the engine still keeps idling eratically and sometimes the car has a hard time starting hot or cold what could this be ???
