SupraCorwin;1339533 said:I am already running a r154 with a 4.30 not from stock, from a swap and my speedo is 70mph at 60mph gps.
Evilempire1.3JZ-GTE;1340198 said:The speedo is off roughly by 10%
if you use a 4.10 R154 speedo gear drive for a 4.3 diff
So if you increase the diameter by 10% or get as close to it as possible using the jdm 4.1 r154 drive you should be really close.
Moy;1358567 said:Would installing an A340E driven gear onto the R154 work?
