What size head gasket do I use if I have a 0.50 overbore on my block. Will a stock head gasket size sufice or do i need an 86mm bore head gasket.
Thanks again.
Thanks again.
David D;1380771 said:Ok sorry for the confusion. I really appreciate all of your help.. here is the link to the pistons I bought and the size is (.50mm = .020")....http://cgi.ebay.com/ebaymotors/ws/e...witem=&sspagename=STRK:MEWNX:IT#ht_3538wt_925..... with this infomation do u think i can still use a standard size head gasket or do i need a one with a bigger bore.
Thanks again guys :icon_razz
lets review. stock bore is 83mm, you added .5 mm. Your new bore is 83.5mm. An 84mm bore hg will work just fine. you are looking to have your hg bore be slightly greater than, or equal to your cylinder bore.
