What should I do with my stock BOV?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i capped the holes off, then again i just ended up reinstalling the stock valve instead of the hks..
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i would leave it in there, as long as its working, to keep the engine from stalling due to Venting to atmosphere, while still being MAF
thechori
supra-deprived
Oct 3, 2006
567
houston
well couldn't he just recirculate the SSQV? that'd fix both problems, except one of the holes i'm guessing
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
No it's all stock.So I think I'm going to cover the holes I have a few ideas in my head but I would like to hear what you guys did with the 2 holes.So let em roll
TurboWarrior
Canada
The higher psi you go the more likely the stock BOV is leaking. Id eliminate it. I like to eliminate as many potential problems as possible when it comes to the intake tract.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
If it's completely stock I'd stick with the stock BOV, if you delete it and vent the HKS, you're going to have some problems. Recirculating the HKS will work fine if that's what you want to run, a bit of a different sound though.
tlo86
Jul 24, 2005
3,914
Colorado
i recirculated my hks to the turbo inlet although it was a pain to try and find the right fitting for the hks recirculation fitting... i never raised stock boost so i just threw the stocker on with new hoses (reason i got the hks in the first place was my stock hoses cracked :))
