right now iam trying to figure out what i should do next on the supra, in terms of adding power. i would like to reach 350-400hp. my current mods are:
60-1 ct-26 turbo
full 3in exhaust
new HG and ARP's tourqed to 82ft lbs
newer head/and resurfaced
NGK plug wires
Hard pipes/intercooler piping
knock off BOV/but better than stock
wideband AEM UEGO
currently running around 10-11pounds of boost with an air/fuel ratio of 10.3 at WOT, so im pretty rich, and the unmetered air screw is backed out on the afm, so it should be leaner but isnt. i can run about 12psi max, i hit fuel cut at like 13-14. i would like to be able to run 15+psi. if i got a Fuel cut Defender would that allow me to run about 15pounds? and is it safe?
next question, 550s and lex afm... i know those two mods will allow me to add power and run higher boost, but will i have to have like a safc to even run those two things on my car? or would i be able to put the 550s and lex on with out tuning?
60-1 ct-26 turbo
full 3in exhaust
NGK plug wires
wideband AEM UEGO
