what octane am i suppose to use
Toyotaxtreamteam
231
Mass
i hear in a 7mge i am suppose to use the highest grade possiable is that true, and if i put in a low grade would that make my car slugish in low rpms
aye mate
Hiatus over.
Maryland
The Toyota manual says to use 91+ octane.
Personally I use 87 octane cause I get it for free, and my car runs just fine.
Silvasoup
143
Florida
I have an N/A like ToyotaXtream has and I find the Mid grade gas works just fine. I have had good results with Amoco Silver grade. Just use a good brand name gas and I think you will be fine.
N
NDBoost
Guest
7MGE use nothing less then 87-89.
7MGTE use nothing less then 91+
Arizona doesnt really offer many gas stations with 93+ gas, most of them are 91 :(
MKIIINA
Destroyer of Turbos
Plano, TX
87 and youll be fine. start adding forced induction or bumping compression and then you can get the higher gas. your just throwing your money away on it now.
koulee
497
poppincaps88 said:
I always stick to the highest grade I can get for my 87 turbo, which is sadly on 91 octane here in Cali...:nono:
Fucking sux man - I was driving around trying to find a station with 92 or 93, but none. Wasted a whole tank of gas. :icon_razz
mkIIIman089
Ohio
You are semi correct on the manual; IIRC it says a (insert special octane research group here) rating of 91 BUT it says right after that, that the number on the pump should be no lower then 87.
On that note, I run 93 all the time, just because thats the highest I can get locally.
shaeff
Kurt is FTMFW x2!!!!
10
Around
if he has an N/A, then there's no need to tell him what you put in your turbo. ;)
for an N/A, use 87 unless you've increased the compression somehow.
-shaeff
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Yep...87 on the pump sign, per 1989 owners manual, pg. 110.
TURBO or N/A. It also says to use 91 if you want better performance.
I'm sure by that they mean less pinging during hard acceleration, so the timing won't be retarded by the ECU when the knock sensor picks it up.
