what is this??
tmaxx31190
Got Insulin?
Nov 22, 2009
45
Walled Lake, MI
the purge vacuum line on my throttle body was clipped by the previous owner and it just has a screw stuck in it to plug it. what is this vacuum line for?? what are the pro's and con's of having it like this?
Not enough info as to what line you are referring to. Post a pic and you might get an accurate answer.
jetjock
creepy-ass cracka
9,439
EVAP purge line.
Edit: Guess I should explain that. It goes to the BVSV on the t-stat housing then on to the EVAP cannister. It's how the engine burns fuel vapor sent from the tank that got stored in the canister. Put another way to prevent HC emissions the fuel system is supposed to be sealed...
