Okay The pugs that go from your harness ( engine harness ) plug into plugs in the dasj I need to know what the
m1 plug is, the b1 plug and the b2 plug b/c there are more then 3!
I am doing a swap and need to know those
This si for my 1jz swap but I hope the 7m guys here know the plugs thanks!
Wiring the M1 plug is mainly for your gauges
• Brown – Brown from IK2 (ground for cluster)
• Yellow/Black – Yellow/Black from IK1 (Oil pressure gauge)
• Grey/Green – Blue/Yellow of IK1 and Yellow/Green from IJ1 (Engine Light)
• Purple – Black/Yellow from IJ2 (12v switch, alt to charge batt)
• Red/Black – Red/Black from IK1 (Reverse lights)
• Yellow – Yellow from IJ2 and Red/Blue IJ1 (Speed sensor)
• Yellow/Green – Yellow/Green from IK1 (Water Temp Gauge)
• Pink – Pink from IJ2 (Speed)
• Black – Black from IK1 (Tach)
Wiring the B1 plug is mainly for ignition and fuel
• Green – Brown from IK2 (Ground for Fuel Pump)
• Black/Blue – Black from IK2 (NSW)
• White – Blue from IK1 (AT Switch)
• Black/Red small – Green from IJ1 (Fuel)
• Black/Orange small – Black/Orange from IJ2 (switched power, ignition)
• Black/White big – Small Black/White from IJ1 (Starter)
• Black/Yellow – Black/Yellow from plug on engine harness loom (VSV Water)
• Yellow – Red/Green from IJ1 (Fuel)
• Red/Yellow – Red/Yellow from IJ1 (ELS)
• Black/Orange big – both Black/Orange from IJ1 (Switched power, ignition)
• Black/Red big – Black/Red from IJ1 (Fuel Main)
Wiring the B2 plug
• Blue – White from IK1
• Green – Green from IK2
• Yellow/Blue Red IJ2
Wiring the B2 plug
