what is good type of gear oil to put in my R154 tranny?
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
I don't know the weight nor a good brand. Up to knowledge my tranny has never been serviced. Gears feel dry, and can be heard at idle. Could I put Lucas gear oil and something else?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
redline mt90 - you can read about it extensively in jdubs specialty section for lubes and motor oils.
5
Some of the normal auto parts stores carry it in certain areas, but you're best bet are speed shops.
If you need the oil, use a cheap conventional oil until you can get the MT-90 in, all the other synthetics I can think of have friction modifiers in em (bad for syncro function).
This is all covered in the Oil and Lubrication section of the forums...
lagged
1991 1JZ
new rochelle
if they dont have it in stock and you dont feel like waiting, i use mobil 1 75w-90 which is the proper weight for the r154.
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
Alright I will look around tomorrow and If I can't find it then I will get mobil1. Yeah I was looking in my "BIBLE TO THE SUPRA" aka the big red maintenence book from Toyota. It said
Transmission oil-
Oil grade:API GL-4 or GL-5
Viscosity: SAE 75W-90 or 80W-90
Capacity: 7M-GE 2.4 liters (2.5 US qts, 2.1 lmp. qts)
7M-GTE 3.0 liters (3.2 US qts. 2.6 lmp. qts)
However it doesn't really tell me on where to fill it it shows the drain plug and something attached to the side
a remove the drain plug and drain the oil
b reinstall drain plug securely
c add new oil until it beings to run ouit of the filter hole
Do I fill from the top which means remove the shifter or what?
I don't have access to a lift nor have something to pump the fluid so how do i do this?
KicknAsphlt
Occasional Peruser
I just went through this about 5 months ago -- you can put it in through the shifter mount, but be careful as you can overfill it. The best way, albeit more complicated way is to fill it from the filler hole with a siphon pump from the bottle, until it starts to run out of the hole...as the book says. BTW, when I changed mine I used Amsoil Severe Gear 75w90. Felt pretty good afterward, but shortly after my motor chooched, so....*shrug*
lagged
1991 1JZ
new rochelle
if youre working in a shop with a lift it is simply retarded to fill it through the shifter hole.
if you dont however have a lift, then yes it is a little nicer to work inside the car as opposed to on the ground.
also take notice, your repair manual gives two acceptable gear oils however only the w58 takes either or.
the r154 takes 75w-90 only.
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
Thanks I'll keep that in mind. Yeah the only way I can do it is fill it from the top so I will drain it which probaly only about .2 of qt. will come out and just put 3 qts in since the book says the max is 3.2 qts
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
yeah I don't have access to a lift for about 3 weeks. School autoshop is not open. In anycase it has to be done now becuase shifting feels like CRAP!
5
Pull the fill plug and fill till it comes out, underfilling will cause oil starvation and heat, overfilling will cause leaks.
Mobil 1 is overpriced and contains friction modifiers IIRC, I don't recommend it. If shifting feels like crap, you NEED the MT-90...
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
I will try to find but in california you can't find crap anywhere! so exactly 3.2 then huh
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Just go here and buy this http://store.summitracing.com/partdetail.asp?autofilter=1&part=RED-50305&N=700+115&autoview=sku
Clip
Oct 16, 2005
2,738
9
Virginia
i filled through the fill hole without a lift, just takes patience and an assistant to fill the siphon pump with me laying under the car.
7thousandpiecesMGTE
Boostin USA
Apr 9, 2007
469
Harford County, Maryland
uh oh...... I just got my drove my supra from south florida to maryland, about half way 5th gear started a high frequency whine, got off highway and all gears but 4th whine like hell (input shaft bearing gone??) and i bought some lucas tranny oil and put it in to get me home. didnt know that was a nono.... oh well, im either rebuilding or replacing it anyway.
Did get me home though, I love my Supra!
