What have you purchased lately?
williamb82
906
4
Tampa, Fl.
hmm, laptop so i can tune my ms2, aem wideband, autometer oil pressure and water temp gauges, weld in bung so i can transfer my egt gauge to the ss mani, comp cam valve springs for my race head, 0.68 a/r turbine housing for my gt4082, motor mounts for a later planned mkii 2uz swap, ss clutch line for my 84, ss brake and clutch lines for my 85, custom dragon embosed valve stem caps, ss spark plug cover, and prolly more ive forgotten. this is all within the last 2 months or so. to see a more complete list look at the cardomain pages for my cars.
rakkasan
Currahee!!
Fort Campbell, KY
-1J / 5-speed clip
-Koyo Radiator
-Y pipe/DP combo
-Lightened Flywheel
-SPEC III Clutch
-BIC 1J motor mounts
-3" 304SS pipe, mandrel bends & resonator
-lot's of misc parts
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
eibachs and KYB GR-2s, and the car is at the mechanics now.
Tase, any clue when the ecu and harness will be avaible for sale? early or late 89?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Bought a used fuel door and speedo cable from chriso (thanks Chris! Got them both installed everythings A OKAY now). I put those on saturday, BTW, anyone need a good working upper speed cable?
Two Red silicon vacume hose kits from Autozone
OBX oil catch can
OBX coolant resivoir tank
15' of hose for the catch can, one metal tee, and one metal 90 degree elbow
New clutch master cylinder
New Clutch slave cylinder
Techna Fit RED SS clutch line
XTD Stage 3 six puck clutch kit w/new TO bearing and Pilot bearing
Soon to come:
Treadstone intercooler
hardpipe kit (leaning towards LIPP's kit)
HK$ ssqv and flange
RS-R exmag exhaust or similar one (JIC)
After that:
Replacing most of the bushings with poly ones
New ball joints
LIPP traction arms
ST F+R sway bars
Strut tower bar (haven't decided on brand yet)
CP rear 4-point strut bar
5 point harness kit from suprasport
racing bucket seats (I like the shape and design of OTTO-R's from ebay)
Installation kit for seats (anyone know where to get these?)
I-Rotors drilled/slotted F+R rotors
Metal Master's (or equivilant) brake pads
Techna Fit SS brake lines
Later on down the road:
Old 7-MGTE engine
Mild port and polish on head
New valve train components
1mm oversized valves
HK$ 2.0mm STOPPER HG
.20 over JE pistons
Eagle H-Beams
ARP everything (head studs FTW)
Clevite bearings (wishes the 77 series was still around)
Machined crank for bearings
Machined Head and Block for the HG
New oil pump (shimmed FTW)
New water pump......................You get the idea. ;)
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
lets see
Front Strut Bar - thanks Celica Supra
Euro Gauges - Thanks xrated69
JVC car deck with ipod adaptor
winter plans : Pull out engine and rebuild, paint engine bay to match the rest of the car and myabe a 5 speed swap if I can find the tranny and all the necessary parts
LuvMySilverSupra
Bay Area Supras
Bay Area, CA
well, since my welfare checks have been a little light the last few months, all i have done is gotten the 360 serviced ($12k), bought another rolex for my mom's birthday (today 10-10) (lady's rolex white gold # 179179 ~$8500)
coming up: this monday is my 22nd birthday (10-16) so we're going to Ruth's chris Steak house again and i heard they have king crap and lobster to go with the steaks so it'll be about $2000 for dinner and wine.
that's all for me, hopefully the government will stop fucking up with my checks and my other "businesses" will pick up a little.
SoupedUpSupra
The guy.
Sonoma County, Norcal
87 Silver Sniper said:
lets see
wow that's a nice sig you've got there, where did you get it, my COPYRIGHTED deviantart page? :ugh:
http://www.deviantart.com/deviation/32539168/
My copyrighted image, over 6 hours of work:
Your sig:
Thanks for asking for my permission to use my image. :ugh2:
Squid699
Manic Mechanic
Chesapeake, VA
fidanza flywheel (used)
fidanze friction insert (new)
Centerforce Dual friction
Dyno time is next
Edit: but I have been buying a lot more other non-supra stuff. lol.
Gilsdorf
Street Dragon
Jun 18, 2005
244
Reno, NV
Within the last 2 weeks:
Ron R Short Runner Manifold, Q45 throttle body, mkiv throttle cable. atlernator relocation bracket
780 RC injectors
GTR Intercooler, t-bolt clamps, 4-ply couplers.
3" custom stainless steel hard pipes
4" custom stainless steel intake pipe
HKS SSQV
MSD-4
Hayabusa coil on plug set up
Moroso crankcase evacuation system
Goodridge SS brake lines
Stern 18"x8.5 front, 18"9.5 rear ST-1 wheels
BFG 245/40/18 + 265/35/18 KDW-2s + (winter tires for other DD)
Lotek Triple gauge pod
AEM UEGO wideband controller and guage,
GM boost solenoid
DEI exhaust wrap kit
Dyno time
Within the last 2 months:
Wiseco pistons .040 + rings + machine work
HKS 2.0mm Stopper HG
Factory Toyota wiring harness (new)
Canton Racing Accusump, electronic valve controller, N/A filter stud, canton remote filter adapter, CM 8micron spin on filter, -10 AN SS lines
Earls oil cooler, thermostat, -10AN SS lines and fittings
Rebuilt progressive steering rack, with lines, and Suprasport Poly bushings
Lipp traction arms (aluminum)
LIPP EGR block off plates
Suprasport FPD elimination kit
Rebuilt starter
Rebuilt 80amp alternator
Water pump, thermostat
Factory Toyota Fuel level sender
Redline oils--trans, diff
Within the last year:
AEM EMS
AEM IAT + MAP sensors
Innovative LM-1 Wideband w/RPM input*
Magnacore 8.8mm wires*
Iridium 1colder plugs*
Greddy catch can
Factory Toyota battery cable
Shineauto east bear lip replica
Factory Toyota replacement fog lights
Greddy Airnix filter*
Within the last 3 years:
SurpaSport BOSS 550 dual BB, big shaft 58 trim
Lipp SS elbow
RT downpipe
Greddy SP cat back
RT test pipe
Spearco IC*
Defcon hard pipes, ceramic coated*
Greddy type S BOV*
Lexus AFM*
RC 550's
Walbro 255 pump
SupraSport AFR Fuel solution
Ross .17 over, ceramic and dry film coated by swaintech* (one melted, rest are good)
Pauter rods
Toyota bearings
Ashino (Toyota OEM) oil pump
rebuilt head, heli-coiled exhaust studs
Cometic 1.4 HG*
MSD 8.5 plug wires*
Irridum plugs*
ARP head and main studs
ported exhaust manifold
K&N Fipk**
PWR Rad
FAL 220's with temp switch
RPS flywheel
Spec 3 clutch
SS clutch line
SupraSport v3 short shifter
Safc 2** (pending payment)
Avc-r*
Hella H4 housings, PIAA bulbs
KevinM Rear sun shade
ST sway bars
ROH Drift-R 17x8* 235 45 Mich pilots*
Brembo cross drilled F+R (BBK coming soon)
Metal Maxis pads
Eibach and Tokico II's
F+R greddy strut bars
Leatherseats.com leather and seude interior
Factory Toyota Super White trim
Lotek dual pillar pod, with Auto meter boost and egt
Factory Toyota center arm rest and shift boot
*FOR SALE--pm me
**SOLD
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Jim king Bolt on kit. LM-1 days old throwing error code 04 pump failure first 15 minutes of running, 2 Toyo 285 35 18 T1r's, CSF aluminum radiator, Boost Logic turbo blanket. Drift hood, Bomex big mouth bumper replica.
In 2 weeks time hopefully a Haltec E11v2 Wilwood Big brakes 6 pistons.
