What happened to this fuse????
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
while playing in the kickpanel i thought i'd check my voltage there and i found this at my foglight pins :/
It hasn't blown the fuse but it seems that wire has had some excessive heat?
Way back i used to have problems with my foglights blowing bulbs and it was shorting out at the bulb so i fixed that but since then i can't remember if i have replaced the fuse or if this is since then
supramk3man
414
kentucky
could have even been some wrong with the fuse its self i have seen some before do that because the fuse was cheaply made or the contacts on the fuse wasn't right just a thought
