while playing in the kickpanel i thought i'd check my voltage there and i found this at my foglight pins :/
It hasn't blown the fuse but it seems that wire has had some excessive heat?
Way back i used to have problems with my foglights blowing bulbs and it was shorting out at the bulb so i fixed that but since then i can't remember if i have replaced the fuse or if this is since then
