drbowser3 said:To clear things up, when I state "sanding" basically what I am saying is, using 2000 grit sandpaper on a sanding block. I remove any part of the stock HG that remains, getting it as close to the stock surface as possible. Therefore not much if any material has been removed. And also, when using an exstension while torquing you lose torque, therefore 90 ft/lbs, does not equal 90 ft/lbs. Also I the 2 stock HGs I have hanging on my wall, un-used measure out to be 1.47 mm, uncompressed. So if you have your head resurfaced, not milled, which both times I have done HGs, the usually take off .003" off which=.07mm. Just some facts for people who think my motor is GHETTO. RUns great, and when I feel the NEED to do a leak down test, I will send the numbers. This is a stock bottom end build, when I go forged, everything will be machined to spec. But it is just funny how many cars are done like this with no problems....
jdub said:Yes I'm splitting hairs, but someone that does a MHG install needs to know the RIGHT way and make their decision to cut corners.
Wanna prove your point...post some compression numbers.
