What FPR should I use?
5uprahboy
343
Auckland
As the subject suggests.
I'm looking at making around the 220rwkw mark from my 2 Litre.
Will be using 440cc 7M-GTE injectors, HKS S-AFR and VPC.
Have Bosche 014 in tank.
Cheers
Hunt
shaeff
Kurt is FTMFW x2!!!!
11
Around
2 liter? what 2 liter? the smalles supra motor was 2.5 liters.
back on topic: i use an Aeromotive adjustable fuel pressure regulator with no problems. it is regarded as one of the best. SX also makes a good one. i love my aeromotive, but it's pricey.
-shaeff
I
itr206
Guest
Aeromotive isnt pricey at all. I just ordered one from summit yesterday for $135
Thats cheap for a quality regulator .
I ordered the AEI-13109
staticpat
Supra Chair!
Birmingham, AL
How necessary is it to have one with the boost reference and rise ratio? I need a afpr myself and I'm going to get dyno tuned as soon as I install. Do I really need one that dumps in extra fuel for more boost?
mullenc525
33
You need one with a boost reference. This is not to dump in extra fuel under boost, it is to keep the pressure difference between the fuel rail and intake manifold the same, so that for any given injector duty the same amount of fuel will flow.
You do not want a RRFPR. RRFPRs are for hondas and other ecus that cannot electronically compensate for boost. Instead, the fuel pressure just gets really high. Its a crappy way to tune, its like having a hybrid efi and carb setup under boost (although all the fuel still goes through the injectors, half of the tuning is mechanical).
IHI-RHC7
"The Boss"
Oregon
Yup. Aeromotive.
I don't believe I've ever seen an EFI regulator that isn't vac referenced...
IHI-RHC7
"The Boss"
Oregon
She has like 5 sitting out of her house and has spoke of herGA many times. Her yellow car is not a Ga
5uprahboy
343
Auckland
Ah - well in that case - I guess - but she has not ever had a GA-70 running - other than her mums old one - but that went some time ago - hehe oops - off topic :)
I
itr206
Guest
Or you can get it for $135 from Summit and make the lines for a few bucks.
IHI-RHC7
"The Boss"
Oregon
I almost wish we had purchased the kit, the bracket and all really help the install go smoothly. But yeah, it cost $20 for all the fittings and stainless from our local hydro fitting supply house.
