What does your Oil Pressure Gauge read at idle?
mkIIIman089
Ohio
ma7089 said:
what about your viscosity?
I won't disclose that... its top secret. ;)
"Operating temp" does not mean your water temp is at 88C, or that the stock guage is half way. It means driving for a minimum 15 minutes at somewhere around 3k rpm. Much more if its cold outside.
my7mgte527
im having a similar problem rite not at idle my oil pressure is almost at zero i cant seem to figure it out ive been i have my car filled with oil also so im not sure on wat to think . to top iit alll off my co workers r saying im leaking oil but there i cant figure out where
airhead04
1,489
Lima, Ohio, United States
First, damn thread revival. Second please try an use better punctuation/grammar.
Now, did you read this thread at all? Everyone agreed that your gauge is going to read low. But you do need to find that oil leak.
8,893
There is two internal leaks. The piston squirters and the cooler circuit. When the engine is warm, the needle will barely be above zero. Get a mechanical tester, and test warm. If you eliminate the factory pressure bypass circuit, and go with a temp controlled thermostat, it will read higher at idle. A little.
