What do you think of this eBay gasket set?
Kai
That Limey Bastard
I got the same gasket kit from Eristic Gaskets as theWeezl, and i have to agree, very comprehensive, all well made, comes with valve stem oil seals too. I got my bearings and thrust washers from them too - although they're ACL's.
I also have the same piston set. The tops are indeed ceramic coated so although they're cast slugs, they're still a shade better than OEM ones. They came with wrist pins and circlips, and the same NPR piston ring set. All have been given the thumbs up by his holyness, Ed, and Ed's machinist. I got 20thou oversize pistons as well.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Sawbladz said:
What all gaskets should I use FIPG for and what requires a specific gasket from a kit like this?
The oil pan gasket and the two little spots on top of the timing cover should have FIPG on them, I'm sure there are other spots too...
