bigaaron said:
When the weight of the wheel is not listed, it is probably heavy. If you are buying wheels for performance the weight is important, the size of the lip is not.
Agreed. But most of the Enkei's are not too bad when it comes to weight. The 5Zigen's you have, are some of the lighter wide wheels available. Also, the Enkei RPF1's, which are even lighter than your 5Zigens, but they are alot pricier too! I think that unless you are going for extreme high performance, any rim 25lbs or lighter, are okay. Your 5Zigen 17x10's come in at around 21lbs.(?) Those hideous things you posted earlier, are probably around 40lbs+, each!:aigo: = degraded performance and worn parts.:icon_mad:
