what do u think of my gt35r dyno
bigaaron
4,692
Pomona, CA
www.driftmotion.com
itr206 said:
Why does everyone assume because its a BB chra that its gonna be this amazing spool. Your lucky if you see more then 200rpms difference in spool. His charts look totally normal to me.
I totally agree, every time someone posts a dyno sheet using a big turbo everybody says it looks laggy. That gt35 is a pretty big turbo for a 2.5l or even 3l motor to get going. Plus he is pulling from low rpm in 3rd or 4th gear, the chart shows hp output, not spool. I bet that thing is fun as hell to drive. Even though a 1jz may spool 800-1k rpm higher then a 7m with similar turbo, you still have 800-1k rpm more powerband before you hit redline.
lowbudgettarga
supra and I - Broke
Apr 2, 2005
109
Bellingham, WA
it doesn't look that laggy. my roomates gt35r on his 7m untuned hits full boost around 4k in 3rd (that's just watching the tach, not off a dyno chart) and made 450 at 18 lbs. I'd say your numbers are pretty good and the car is probably a blast.
92sc3001JZ
14
tampa fl
nope im not itsnotasoarer.. thats a guy that has a friend with almost the same setup... i was thinking of getting a ecu first since im on a stock soarer ecu..???
This is pretty much the exact same setup I'm going with. Aaron has found me a Garrett gt35r. I was looking to make 450 and I may do it too, because I've got gams ordered.................:evil2:
When you dyno this next time, video it and post it up here....................PLEEEEEEEEASE.
Aaron is offering a plug and play standalone right now. www.driftmotion.com
I'm not going with a standalone right now, but may in a couple of months. I want to get it running for now. I am also buying a laptop, so I'll have that ready for my standalone................lol
