what do i need to swap a w58 with a r154
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
like it says what parts do i need for the swap
im pretty sure all i need is the tranny and the drive shaft is there any thing else?
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
you will also need a pressure plate and clutch.
and I think you will need a slave cylinder but I'm not 100% sure cause I have never done this.
Why are you doing this? The w58 is a good transmission and shifts better then a r154.
s turbo 87
Accepting Donations
Louisville, KY
lets see a w58 handle 350+hp for an extended period of time.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
The R-154 is a lot beefier than the W-58 and can hold a lot more HP. I shifted the w58 and it seemed sloppy compared to the r154.
I think that you might need a flywheel too. Not sure though.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
a properly maintained W58 will handle a fair to good amount of horsepower for a while before failing (with proper clutch), and in almost all cases the W58 shifts smoother and easier than the r154.
what is Sniper's reason for doing this? looking at the profile, he's NA. either he's preparing for a lot of power or this is what he could get his hands on easiest to replace an ailing W58.
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
yah i did seach lol but not on google doh
anyways my reasons for going the r154 is i broke my w58 and was looking a replacing it an itturnd out to be pretty close to the r154 and seeing as im going 1j anyway i might as well just get the r154 now and the just get the 1j bell houseing later.correct me if im wrong but i think thats how i can do it
SupraChrisMk3
New Booster
Feb 8, 2006
170
Salisbury, Vermont, United States
I've been thinking about doing this swap too. My w58 grinds 2nd bad, is a pain to get in reverse and sometimes into 1st. Not to mention that overall it shifts like shit. But all that is probably sue to the fact that when I bought the car, pretty much all of the bushings in the shifter were either extremely worn out or disintigrated already. I replaced them all when i did the SOGI short shift, but i think the damage has already been done because it still feels like shit.
Clip
Oct 16, 2005
2,738
9
Virginia
ooh, i f'cking called that one! and you're right, as long as you get the 1j bellhousing the r154 will mate up to it.
