sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Installed the much smaller brake booster to clear my intake manifold
Sent from my XT1635-01 using Tapatalk
seoul4korea
620
San Diego, CA
www.supraforums.com
Started to put together the rear subframe.
Battle Version suspension to include sway bar end links
ST suspension sway bars
Half of a Energy Suspension poly kit
Energy suspension poly Ball Joint Dust Boots
New OEM wheel bearings with seals
New OEM Spherical Bushing
Ronnie K Subframe bushings
yhatzee89
Joe Yantz
Aug 31, 2012
977
San Antonio, TX
Installed my euro turn signals on my JDM car. Couldn't be happier with how they look.
Also got my TRD oil cap in the mail and put that on
Overall: a really good night
Sent from my iPad using Tapatalk
yhatzee89
Joe Yantz
Aug 31, 2012
977
San Antonio, TX
dropped a bolt somewhere down the front of my engine while fixing the cam cover leak. then, while trying to remove the lower timing cover, I got a ratcheting wrench pinned against the back of the dampner.
yhatzee89
Joe Yantz
Aug 31, 2012
977
San Antonio, TX
Found the bolt that I dropped and got it back up and running. Also finally installed my Takata tow straps. Aren't JZA70s supposed to have a special tow hook?
Raggan
142
Maple Ridge, BC
Nice job on that harness Raggan. Are you using 1" braided sleeve on the big firewall section? Also did you use a heat gun to keep it from upbraiding at the ends and splits?
Thanks. Yes it is 1" braided sleeve and half inch under the timing cover area. I used a heat gun for the shrink wrap on the harness. What I found works is heating some scissors up and then cutting the loom also where you want the wires to pop out of the loom like injectors etc. just cut a small slot. The wiring harness was pretty easy it just took a lot of time because, it's my first time building a harness like this. It's not perfected but, I tested the harness and it works.
some updated pics
I still have to put the horn plug on, transmission reverse light plug, Heater valve plug,shorten the boost control wires & finish wrapping the coil plugs
88SupraT
Boosting Supra
Apr 4, 2005
135
North Vancouver, B.C.
It was a hell of a lot of work but it's done, I just have to finish plumbing the oil catch can. Having issues with it idling properly, hopefully the tuner can sort it out.
photo image hosting
awesome work! Will hopefully see this thing rolling around the lower mainland this coming spring/summer. Who are you going to for you tune when you're all finished with the smaller detail?
