jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Snow performance water/meth injection kit, I'll get more pictures of the install once I get my better camera back from my sister
rhs
147
Dallas
Put in an oil catch can, actually mounted my dipstick with more than zipties, and slapped a filter straight onto the IAC. Engine bay is finally looking mildly respectable.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Polished my fuel rail, we'll a little but more than what it was. I'll have to get a buffer wheel for my drill next time
Sent from my LG-LS980 using Tapatalk
300K91T
15
IL
View attachment 77830Water Leaks!!
Finally took the time to investigate leaking sunroof. Removed enough interior to remove headliner and was expecting (hoping) to find a clogged drain tube(s). However all drain tubes were clear, so ended up having to remove the entire sunroof assembly. Turns out that a caulked joint near one of the cable tubes had deteriorated enough to leak...not so sure a mouse did not have something to do with that deterioration, some new silicone sealant and Problem Solved!
Since all of the rear interior was out of the car, also investigated the water leak in trunk area. Mine was the result of a missing nut on the lower back glass molding; Problem solved. Pics show the leak, the leak area while assembly was still in the car, and a freely draining drain tube exiting beneath the trim piece behind the door window.
George_Bonilla
114
Northern Virginia
www.instagram.com
The previous owner put in an aftermarket stereo a LONG time ago and it doesn't works. I haven't been able to listen to music since I bought her... I took a stereo out of a donor Honda Accord. Swapped it out and it sounds awesome.
Only took a picture of the wiring:
- Top left, old Supra wiring.
- Bottom left, crappy Accord wiring.
- Right is the finished product.
Mk3SupraSaiyan
8,898
My Aisin sourced water pump is on the way and will be here today. I bought it outside the Toyota network to save on the margin. You can do this with many parts and manufacturers, if you did not know. My pump started to leak and it needs to go.
George_Bonilla
114
Northern Virginia
www.instagram.com
Saturday maintenance plans for the supra:
- Cusco Oil Catch Can
- Complete vacuum hose kit
- Valve Cover gaskets
- Valve Cover phillip screws replaced with bolts
- 3rd Valve Cover gasket replaced with Napa Oil Drain Plug gaskets part # 704-1076
- Fix annoying wind noises from window corner seals
Mk3SupraSaiyan
rhs
147
Dallas
Valve cover gaskets and I mounted a gauge pod on the A pillar. The former went great, the latter not so much. Discovered the trim is foam glued to some sheet metal. I got one screw through the sheet metal and said "screw it, good enough." For once I wish the trim was plastic...
