zonian91
84
This is an OBX Racing crank pulley and it has a slot for the Woodruff key and I got a new one too.
Sent from my SM-N900P using Tapatalk
zonian91
84
Here are the pulleys side by side.
zonian91
84
Even with a brand new balanced crank, new Clevite racing bearings, new ARP rod bolts?
Sent from my SM-T330NU using Tapatalk
zonian91
84
I understand basic physics, but I still can't see how the crank will be out of balance with everything holding it in place.
Backlash2032
1,823
Nebraska
It's not the crank being out of balance. It's the explosions that are forcing it to spin that cause the inherent vibrations.
Sent from my HTC6525LVW using Tapatalk
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
zonian91;2056032 said:
Why is everyone saying this? This motor has been rebuilt from the crank up and it weighs a ton! How is 7 1/2 lbs going to make a difference in the balance of the motor?
Read please. People are telling you it's bad for a reason. If you don't want to listen, read the thread
http://www.supramania.com/forums/sh...iftmotion-underdrive-crank-pulley-good-to-use
It doesn't matter how buttery the crank turns. But you're welcome to put it on. I'm not bashing, just throwing out some info when I was hell bent on getting one.
Grandavi
2,664
Calgary, Alberta, Canada
Basically you have to think "harmonic" (harmony... Music is vibration) "dampener". It absorbs vibration so the crank doesn't self destruct. Unless you understand mechanical engineering very well, go with the proven solution. Alter at your own peril.
Just read the link above... Excellent material.
zonian91
84
Trust me I know. I built, what I thought would be a bad ass 5th Generation Prelude and the machine shop I USED TO use to put the motor together, did something wrong, because the motor became oil starved, so it started knocking, so I got rid of it and stopped the bleeding.
The car ran like a champ, until it started knocking.
526
Cambridge
Oh yeah, mine had the slot, but t shop that sold m my lathed tensioner pully said, "all aluminum, I have seen the crank rip the key through the pulley " so he was referring to a steel sleeve insert t reinforce the pulley.
I'll be going fluidyne, next tim I drop some supra monies
zonian91
84
Ok, I think I understand what you're trying to say, but where will the sleeve go around the pulley.
#04
526
Cambridge
The sleeve will go on the very inside, to reinforce the area the woodruf key transfers energy to
Most designs do not incorporate this steel (ring basically) into the aluminum.
zonian91
84
Thanks, but I see why that cheap ass regular aluminum crank pulley failed. Mine is made out of aircraft billet aluminum and I'm only going to have about 250 hp at the crank, not 600 + hp! Jesus, you need heavy duty parts when you're pulling that many horses!
Sent from my iPad using Tapatalk
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Just go ahead and run it............................Report pics and post back when you do the tear down.
zonian91
84
I can sense your obious sarcasm, by the way. I do appreciate all the advise. I just will hate to use that old ass rusty looking, heavy ass harmonic balancer! Why would these companies sell you a product that will cause catastrophic failure? I don't get that.
