ryansmith;1851919 said:Received my head gasket kit, looking for two n/a cam covers and a air intake manifold now
I have two pairs but i think shipping would kill ya :crazy1:
ryansmith;1852140 said:Huh. thats pretty cool what they are doing there... I'll try find some closer to New Zealand if not ill email these guys, cheers
gsxr141;1852271 said:this.................. my "new" wheels and tires. 18x8 +40, and 18x9.5 +35
https://sphotos.xx.fbcdn.net/hphotos-snc7/394763_10151868077635154_1217226110_n.jpg
don't worry, my kyb's and h&r springs will be on by the weekend.![]()
Doat;1852273 said:i stripped one fucking head bolt......... trying to think of how I can get it out.
Wouldn't making it jump damage the threads?Numba1Stuna;1852286 said:Just DON'T keep torquing on it the same way! Try going back and fourth after using a solvent. As an alternative if you can find a way to apply upward pressure while wrenching, it will increase your chances of jumping to the next thread. I had the same issue with my master brake cylinder. Used a chisel and hammer to jump threads. Ended up using washers as spacers for the stripped area, but that won't work for the head...
Sent from my LG-P999 using Tapatalk 2
A big easy out, probably going to cost as much as an inhex, a 10mm allenkey cut 2" off the end and hit it into the bolt with a hammer and get someone to tack weld it to the bolt head, then use a 10mm socket to undo it.Doat;1852305 said:Is there another way? It would be nice to have like a list of methods because at the moment I am broke lol
Yea a friend of mine was saying we might have to weld something on and get it out that way. Well the 7m I have has been well taken care of, 81k miles and I don't plan on driving it often anyway just need to replace the head gasket and a few other gaskets along the way and it should be good to go.IJ.;1852306 said:A big easy out, probably going to cost as much as an inhex, a 10mm allenkey cut 2" off the end and hit it into the bolt with a hammer and get someone to tack weld it to the bolt head, then use a 10mm socket to undo it.
Seriously though if you're broke the Mk3/7M combination is the wrong car for you...![]()
IJ.;1852299 said:"Jumping" WTF are you on about... :nono:
Soon as you get 1 full rotation of engagement and keep the Tap vertical in the hole it's not ever going to "jump" threads.. seriously I have NFI where you guys pull this total and utter bullshit from...
