No Here straight from optima's website
How do I charge a deeply discharged battery?
If an OPTIMA battery is deeply discharged (below 10.5 volts), most basic chargers will not supply a charge. Also keep in mind that an OPTIMA battery will not recharge properly if treated as a regular flooded or gel battery. To charge the battery, you can wire a second fully charged automotive battery (12+volts) to the discharged AGM in parallel (+ to + and – to –). Then hook up the charger to the deeply discharged battery, setting the charger at 10 amps. Leave for two hours, monitoring frequently. During this process, if the discharged battery gets very hot or if it is venting (hissing sound from vents), then stop this process immediately. When the discharged battery reaches 10.5 volts or more, remove the standard battery and continue charging the AGM until fully charged.
For normal charging, a relatively low current, such as one or two amps, can work well, but when the battery has been deeply discharged, some sulfation of the battery plates may have occurred. If you charge at 10 amps, the higher current will help to break up this sulfation.
If you have an automatic charger, let it run until the charger indicates charging is complete. If you have a manual charger, you can get a rough estimate of the charging time in hours of a completely discharged battery (11.2 volts) by multiplying the capacity (amp hours or Ah) of the battery by 1.2. If your battery is not completely discharged, the time would be less.
In most cases these steps will recover an AGM battery. It’s OK for the AGM battery to get slightly warm during the charging process. If it’s hot to the touch, it means there’s a short and the process should be discontinued.
I also have heard great things about odyssey batteries but jetjock are they as bad? They are still spiral cell AGM....( I don't know why I referred to the optima as gel) .... I know better
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
