Poodles;1888740 said:Nope, as it goes off the AFM signal
He's using 7M-GE electronics, so 440s would be too rich. You'd be right if it was GTE electronics though.
Backlash2032;1896265 said:He's using 7M-GE electronics, so 440s would be too rich. You'd be right if it was GTE electronics though.
Poodles;1896293 said:Nope, he's using GTE electronics (read the first post)
RazoE;1888713 said:Na electronics on an NA 2JZ-GE can be done, here's my 92:
It was actually harder than going 2JZ-GE on 7MGTE electronics. Only thing you'd have to worry about is pulling fuel, as the 440's off the 7MGTE would be too much for a 2JZ-GE without a turbo.
Dan_Gyoba;1898960 said:And as for range... I'm pretty sure that even a bone stock 7M-GTE is able to pull more air than a BPU 2JZ-GE... Well, maybe with a shimmed wastegate or something.
suprarick;1896015 said:Ok guys, it seems like there are some misconceptions here in the replies and I want get everything clear for not only myself, but for others that search the topic as well.
It seems as though the 7MGTE electronics, harness, ecu, etc. WILL work fine with a 2JZGE from an early 90's lexus/toyota 2JZGE. I'm not sure if there will be ANY complications because it would be going from a turbo motor to a naturally aspirated motor, but some have said as long as it's a 3.0 inline 6, the computer and electronics should be fine (it will just run like a turbo car with no boost coming on).
Confirmation and/or opinions are very welcome.
