I will start by saying im sorry I know this has been asked probably about 4billion or so times but flame suit on I will ask away :icon_bigg
Ok I have a $100NZD(so maybe the price of an expensive pair of boxers) pos chicktiy china 50mm HK$ wastegate which nerves have got the better of me so Im not going to use it now the question is what to replace it with?
My thoughts were either 50mm synapse sycronic wastegate I have heard they are ment to be good but never 1st hand or 44mm tial which people swear by so im sure both brands are great if they are genuine but what about the size?
here are my mods let me know what you think im leanning towards the 50mm but that may just be silly bigger is better mentality.
my 7mgte
.5mm oversized je pistons
eagle h beam rods
toda 264/272 cams
comp cam valve springs
arp head studs, rod bolts, main studs
2mm titan mhg
gates timing belt
600/300/90 dsr intercooler
crank scrapers
ss t3 turbo manifold
crank, crank pully, clutch and flywheel balanced
port and polish head
single walbro 255lph fuel pump
remote filter+oil cooler kit
titan adjustable cam gears
delphi 680cc injectors
custom sump
Masterpower t70 .68A/R P trim turbo + oil lines and turbo beanie
Sard FPR
hks style 50mm wastgate
tial 50mm bov
2.5" ic pipes
3.5" exhaust
big k&n with 4" intake pipe
Link G4 storm ecu
DisplayLink dash
52mm core alloy radiator
thanks in advance scott
my 7mgte
eagle h beam rods
toda 264/272 cams
2mm titan mhg
gates timing belt
crank scrapers
custom sump
Sard FPR
tial 50mm bov
2.5" ic pipes
3.5" exhaust
Link G4 storm ecu
DisplayLink dash
