What are these?
Status
Not open for further replies.
empera
Authorized Vendor
Philly.
Ok im guessing the relay on the left is for the tems but i want to make sure before i get rid of it. But what is the black thing next to the igniter.
heres a pic.
thanks,
-emp.
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
black thing next to the ignitor is the headlight washer relay (someone told me about that one ;) ) the other thing near it is an aftermarket fuse block, most likely for an amp.
the other relay? look likes the fuel pump relay with the resistor pack removed.
tissimo
Stock is boring :(
Melbourne, FL
the one on the left (drivers side) is a tems g force sensor im pretty sure..
The right one is the condensor fan relay (the one infront of the condencer) if you removed or remove the fan you can get rid of it..
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
1. TEMS doesn't have a force sensor. It looks to me like it's the fuel pump control relay.
2. I'm not sure if you're talking about something else, but the big, main box in the circled area on the right is the headlight washer relay, like Matt mentioned. The condenser fan relay is in front of the fuse panel, not behind.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
tems does too have a force sensor
if you watch your lights on the dash if you mash the brakes it'll stiffen it up a bit more
and if yur actually making REAL power and you mash the gas in 2nd gear it will click up one light and get stiffer as well
so yes there is a force sensor
dbsupra90
toonar
indiucky
true, but it isnt a force sensor box per se.
it is judged off of the speed sensor, brake sensor, and steering wheel movement
tissimo
Stock is boring :(
Melbourne, FL
hmm.. i looked at the tsrm it is the headlight washer relay..
I though they tems was supposed to stiffen on hard turns is why I though it had a g sensor.. I guess not..
dbsupra90
toonar
indiucky
ok. go out to your car. turn the key to on, do not start. note how many lights are on the tems indicator. quickly jab the throttle and watch it go full firm.
The system itself is controlled by a main TEMS computer, that is given inputs from: 1) the engine ECU for vehicle speed and throttle position, 2) the steering sensor mounted on the steering column, 3) the 12 v thru the brake light switch and 4) the TEMS mode select switch; that indicate the necessary stiffness level. The output from the computer is then transfered to each of the four TEMS actuators at the tops of each shock tower. The actuators then turn the valve on the top of each shock a certain amount to set the shock either soft/medium/hard.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Just to resolve any confusion for others what dbsupra90 said is correct. Technically well stated too.
Reaper: Better to say "I think but I could be wrong". That way you don't take to much of a hit when you turn out to be ;)
empera: I'm pretty sure that right side relay is for the condenser fan. Course, I could be wrong ;)
The Reaper
Jan 10, 2006
1,909
Florida
oh no i was wrong on a supra board im gonna go emo on myspace and slit my wrist.
i junked the tems the first 2 months i owned the car anyways so i never read into them that much....they are actually pretty worthless.....
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Lol. Here's a another piece of advice: Don't state something with authority then promptly admit you never knew much about it.
I agree it's no big deal but as an SME it's my "job" to prevent misinformation. How important your credibility is on this forum is not my concern. If you don't feel it's worth much that's OK by me ;)
Supracentral
10
mattjk said:
god, what a couple of pompous assholes. you own an old toyota, get over yourselves.
The SME's on this site have EARNED those titles. They are here to be sure people don't get given incorrect or dangerous information.
The original asked a very simple question, and in reply got a lot of ignorant guessing and incorrect answers.
Our SME's are charged with trying to fight that level of stupidity.
So I would suggest if you don't like being called out by "pompous assholes" you admit to yourself that you are ignorant and keeping your mouth shut would be far better for everyone rather than guessing, and giving people incorrect information.
As it says in my sig "The greatest obstacle to discovery is not ignorance -- it is the illusion of knowledge.
Put your illusions away, shut the fuck up and you might even learn something. Or choose to remain ignorant. Either way learn to do it without calling staff members names.
I believe the original poster got his question answered, so this thread has served it's purpose.
Status
