What are the consequences of the 7mgte's ECU not having a speed signal?
nextproject
27
TN
I am swapping a 7mgte into a volvo i have, and am not using the supra's instrument cluster. So i have no speed signal coming FROM the cluster INTO the ECU for the ecu to determine the speed cut. Will the ECU just not bother with a speed limiter? Or will the ecu go into limp mode? Or will something else that i dont want to happen actually happen?
This is just the first of many questions.
shaeff
Kurt is FTMFW x2!!!!
11
Around
There is no speed cut on the 7M... redline limited. ;) Other than that, I am unsure. Perhaps a more TCCS savvy person will chime in to answer that for you.
nextproject
27
TN
you are correct. there are no plans to integrate the supra's cruise control and im running an R154. I just noticed an input on a wiring diagram to the ECU labeled "speedometer input" and figured that there is a speed limiter and this is how it is activated. Thanks for the replies.
