Chris,
There are about 10 different posts about FFIM. Is there a direct advantage:
Yes about half the IC piping plus less heat soak. The manifolds may not flow better at the low numbers they are flowed at yet under boost(huge pressure) the designs would. Check out these pictures and links to see some good information plus check Ron R's sticky.
Your idea of stock manifold with end plate added see below(made 440rwhp with one identical to this):
http://www.supramania.com/forums/showthread.php?t=4780
http://www.supramania.com/forums/showthread.php?t=5401
HTH,
Seth
HTH,
Seth
