WG removed from the Turbo assemb.????
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
I need a new wastegate, and something came up to my mind. Can the wastegate be removed from the turbo assembly???
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
IwantMKIII;1033765 said:
the spring assembly yes, the actual valve that opens and closes not really (at least i don't think it can be removed?).
Not really removed, but you could weld it shut if you really wanted to. You'd need some other manifold setup with an external wastegate... and other manifolds that accept the CT turbo don't really exist.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
only thing i think you could really do is use a T4 mani and make an adapter for the CT somehow, with the right CNC program and machine shop, you could do it.
